Hi, I'm running v5.6.9 on a 64-bit VM CentOS 7 server.
My tech support says the last upgrade overwrites /usr/lib/systemd/system/nrpe.service
This causes a complication for them, but they have a work-around.
Can you give me more information on why this happens?
Thanks!
Earl
nrpe.service overwrite?
benjaminsmith
Re: nrpe.service overwrite?
Hi Earl,
Also, can you describe the complication ( and the workaround)?
Thanks.
This most likely the result of the install script updating NRPE. What version did you upgrade from?This causes a complication for them, but they have a work-around.
Thanks.
Bitflogger
On further examination, it seems that there was a "less than clear" result from a process related to extreme standardization (Puppet).
We have one System Administrator for about 100 servers.
Please close the case.
Earl
Earl
benjaminsmith
Hi Earl,
Sounds good. Closing.
Thank you for using the Nagios Support Forum.
