integrating nagios with jira
taruk
Post by taruk »
Hello ,
im working to intergrate nagios with jira ( nagios to open ticket in jira), i have found already a related topic but i could not add a comment cause its closed,
at this stage im just trying to get information from rest api in jira , the problem is i get error with internal error 500 in my nagios box, after some tries with postman i figured out that i need to deactivate ssl verification and and configure global proxy settings in postman,
is there any method to modify the script to get the same configuration,
script that im using :
#!/bin/perl
use strict;
use warnings;
use JIRA::REST;
use Data::Dumper;
use LWP::UserAgent;
use IO::Socket::SSL;
use Getopt::Std;
use Getopt::Long qw(:config no_ignore_case bundling);
my $jira = JIRA::REST->new({
url => 'https://x.x.x.x/',
username => "**********",
password => "************"
my $baseurl = $jira->GET('/rest/api/latest/issue/INDUS-25408');
print Dumper($baseurl);
Re: integrating nagios with jira
Post by Box293 »
Can you please provide a link to the topic you are referencing?
taruk
Post by taruk »
Hello thnx for the reply here the topic that im folowing:
https://support.nagios.com/forum/viewto ... 62&start=0
taruk
Post by taruk »
@box293 topic followed : https://support.nagios.com/forum/viewto ... 62&start=0
hello after updating my script i could use the api to get a ticket information , the problem now is when i want to post a ticket i got this problem below (see attachements), here is the new code :
#!/bin/perl
use strict;
use warnings;
use JIRA::REST;
use Data::Dumper;
use LWP::UserAgent;
use Getopt::Std;
$ENV{PERL_LWP_SSL_VERIFY_HOSTNAME} = 0;
#my $bot = LWP::UserAgent->new(
# env_proxy => 1,
# keep_alive => 1,
# timeout => 300,
# ssl_opts => {
# verify_hostname => 0,
# SSL_verify_mode => IO::Socket::SSL::SSL_VERIFY_NONE },
url => 'https://jira@',
username => "tchehidi",
password => "*********"
#$ua->proxy('http','http://*********:********@*******.201:8080');
#my $baseurl = $jira->GET('/rest/api/latest/issue/INDUS-25408');
#print Dumper($baseurl);
my $issue = $jira->POST('/issue', undef, {
fields => {
project => { key => 'INDUS' },
issuetype => { name => 'Incident' },
"Component/s" => { "Project Monitoring"},
Location => { "Vermeg-Malaren"},
SummaryRequired => "[NAGIOS] Hostname: Service: State:",
Description => "Hostname: Service: State: Info: DateTime:datetime"
taruk
Post by taruk »
sorry for the time wasting , i resolved the problem , it was the components field it must be an array with the post pethod , thnx
benjaminsmith
Post by benjaminsmith »
Not a problem! Glad it's been resolved.
Thank you for using the Nagios Support Forum.
