NRPE: Unable To Read Output
davidrk
Post by davidrk »
/usr/local/nagios/libexec/check_nrpe -H 192.168.1.4 -t 30 -c check_init_service -a 'amavisd'
NRPE: Unable to read output
Running Nagios XI 5.6.10
CentOS 7
Found a FAQ with this error, and tried those fixes already, and nada.
NRPE had to be installed via YUM, since the agent installer failed.
Any help would be greatly appreciated.
benjaminsmith
Re: NRPE: Unable To Read Output
Post by benjaminsmith »
Hello David,
Thanks for joining the support forum. Welcome Aboard!
Did you add the command definition to the nrpe.cfg file and re-start nrpe? Also, let's verify the paths are set correctly? What is the output to the following command:
find / -name check_init_service
Log in as nagios , su - nagios, user and test the check command locally on the host running NRPE. Are you able to get the correct output?
Reference
NRPE - NRPE: Unable To Read Output
