Hi all,
Please help me on this, i am in need of monitoring dell switches like port up or not & uptime, bandwidth utilization so kindly do the needful what plugin i need to install and what command should i define.
Thanks lot,
Vignesh,
How to monitor dell switch
- Box293
- Too Basu
Re: How to monitor dell switch
I suggest you try out Nagios XI, it includes a switch monitoring wizard which automates the configuration of everything you just mentioned.
Otherwise you need to integrate MRTG with Nagios and also use the check_ifoperstatus plugin to detect port status.
