SQL Error [nagiosxi] : ERROR - Service update
saber
Post by saber »
Service Status Detail => Configure => Re-configure this service => Monitoring , change a value under "Monitor the service with this command: (Advanced users only)" and then Update. There is an error even if the modification is done successfully. I have a attached a screenshot.
Running latest version of NagiosXI (5.6.10).
Thanks!
Saber
benjaminsmith
Re: SQL Error [nagiosxi] : ERROR - Service update
Post by benjaminsmith »
Hi Saber,
Thanks for the screenshot. Can you send over the system profile, so we can review the logs (directions below)? You may have a database issue here. Also, I have a couple of other questions:
1. Are you logged in as nagiosadmin or a user account?
2. Despite the error, does the modification get applied?
3. Is this error specific to this service or does it apply to every host or service>?
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
saber
Post by saber »
nagiosadmin
yes
every service and every host
benjaminsmith
Hi Saber,
Can you send over the system profile when you have a minute? Thanks.
