PDF Reports in Landscape
optionstechnology
Post by optionstechnology »
A lot of our reports are wider than they are long, and the PDF conversion either chops the right hand side off, or it mangles the report trying to make it fit on the page
Is it possible to specify to convert a report into landscape PDF instead of portrait?
benjaminsmith
Re: PDF Reports in Landscape
Post by benjaminsmith »
Hi @optionstechnology,
If you download the pdf report directly you'll have the option to set the orientation to landscape (as a workaround). For scheduled reports, a feature request has been submitted for the landscape option. Right now, I don't have a definitive answer on if and when it will be completed, but I will add your request.
