While attempting to remove an instance following the directions provided in the guide https://assets.nagios.com/downloads/nag ... luster.pdf the step Delete Removed Instance does not work. I get the below error.
This page isn’t working
logserver is currently unable to handle this request.
HTTP ERROR 500
Remove instance from cluster
Re: Remove instance from cluster
Likely running into this: https://support.nagios.com/kb/article.php?id=132
Sorry I did not realize I did not subscribe so I didnt see the reply. I increased all the way up to 1024M and the issue still persists. Please advise.
Sounds like there may be a bad entry left in the database. PM me a copy of it and I can take a closer look. Export it with:
It will be saved in /tmp/nagioslogserver.tar.gz.
I'd also like a screenshot of the Instance Status screen so that I can see the IP address and hostname of the machine you are trying to remove.
curl -XPOST http://localhost:9200/nagioslogserver/_export?path=/tmp/nagioslogserver.tar.gzI'd also like a screenshot of the Instance Status screen so that I can see the IP address and hostname of the machine you are trying to remove.
Fixed in a PM. Removed the node from the nagioslogserver index.
