RestAPI
gregwhite
RestAPI
Post by gregwhite »
I am trying to create a spreadsheet with multiple columns of data that can then be sorted. Each WGet pulls some object data defined by /objects/Hosts. Can you string together multiple objects so pull multiple data fields in one WGet. This would allow you to get more information on a device when you are doing a search.
Example:
/objects/hostgroupmembers/hosts/services/contacts.............
Greg
mbellerue
Re: RestAPI
Post by mbellerue »
I don't think this is possible with the existing API endpoints. You might need to write a script that calls multiple endpoints to pull all of this data together.
Or maybe the custom API endpoints document is for you? Have you taken a look at Help -> Custom API Endpoints?
gregwhite
Re: RestAPI
Post by gregwhite »
Thanks. I'll take a look.
Greg
