Dear all,
I've installed a Nagios Core server 4.4.5 based on Ubuntu 18.04 OS.
I still trying to monitoring a Windows 2012 server but I continue to receive the error CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with xxx.xxx.xxx.xxx
On windows, I've installed NSCP-0.4.4.23-x64,
please could you help me to solve this error?
nsclient.ini- (726 Bytes) Downloaded 802 times
Re: CHECK_NRPE: (ssl_err != 5) Error - Could not complete SS
In the NSClient.ini file under this section
Add all of the following options.
Save the change and restart NSClient++ and test it from the Nagios server using the check_nrpe plugin to see if it can connect.
[/settings/NRPE/server]Code: Select all
ssl options =
allow arguments = true
allow nasty characters = true
use ssl = 1
port = 5666
extended response = 1Be sure to check out our Knowledgebase for helpful articles and solutions!
Hi, Thanks for your reply.
I tried adding the suggested line in the ini conf but the error is the same.
Please, see also my command to test that, (maybe is wrong).
administrator@xxx:~$ /usr/lib/nagios/plugins/check_nrpe -H xxx
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with xxx: 1
Here also the log into nsclient.log file:
2020-02-11 08:14:50: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert handshake failure: 1040
Searching on google and following instructions i also made other test:
administrator@xxx:/usr/lib/nagios/plugins$ /usr/lib/nagios/plugins/check_nrpe -2 -H xxx
administrator@xxx:/usr/lib/nagios/plugins$ /usr/lib/nagios/plugins/check_nrpe -n -H xxx
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
administrator@xxx:/usr/lib/nagios/plugins$ ldd /usr/lib/nagios/plugins/check_nrpe linux-vdso.so.1 (0x00007fff29fb2000)
libssl.so.1.1 => /usr/lib/x86_64-linux-gnu/libssl.so.1.1 (0x00007ff379380000)
libcrypto.so.1.1 => /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1 (0x00007ff378eb5000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ff378ac4000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007ff3788a5000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007ff3786a1000)
/lib64/ld-linux-x86-64.so.2 (0x00007ff37981a000)
I also tied to disable SSL on the ini with USE SSL = 0 and the test goes in timeout. On the log the error is failed to read data end of file
As attachment the new ini files.
nsclient.ini- (992 Bytes) Downloaded 733 times
I attached a new copy of the nsclient.ini file that tested OK on my system.
There were a few options missing which caused the issue.
Just overwrite your existing copy and restart NSClient++ and it should work for you.
nsclient.ini- (1 KiB) Downloaded 2621 times
Hi. Thanks for the support, I tried your in file but the error is the same.
See below:
administrator@xxx:~$ /usr/local/nagios/libexec/check_nrpe -H xxx
-bash: /usr/local/nagios/libexec/check_nrpe: No such file or directory
administrator@xxx:~$ /usr/lib/nagios/plugins/check_nrpe -V
NRPE Plugin for Nagios
Version: 3.2.1
See below:
Version: 3.2.1
After three days i solved following this article:
http://hodza.net/2019/09/21/failed-to-e ... lure-1040/
Thanks tgriep for your support.
Regards
Regards
Glad to hear it is solved!Ponashish wrote:After three days i solved following this article:
Regards
Locking thread
