Hi team,
We have a requirement to check logs from a file where the file name changes based on the date of generation.
We have a plugin check_logfiles.exe which reads the log file to find if any error messages exit.
However, this only supports files with a definite name.
Can you please help or suggest a better plugin or what can we change in the current plugin to get it to pickup files with wildcard in the name?
Regards,
Rebecca Murray
Wildcard file name for checking log files
RebeccaIlene
RebeccaIlene
Re: Wildcard file name for checking log files
Hi Team,
have attached the plugin that we are currently using.
Please suggest on this.
Regards,
Rebecca
Regards,
Rebecca
This is not our plugin but the help can be found here
https://labs.consol.de/nagios/check_logfiles/
I think the only way to di it is with a configfile option, we had a thread similar about 6 years ago where something similar was able to be accomplished in a config file
https://support.nagios.com/forum/viewto ... =7&t=29193
Hello Rebecca!
What might work for you is to write a batch script on your Windows server that wraps the check_logfiles.exe program and passes the current filename to it, kind of like so:
In my example, I'm just hardcoding today's date, but of course in your environment, you'll need to calculate the date and put it into the format your logfiles are actually in.
This page might have some good info on how to wrangle date formats in batch files:
https://www.tutorialspoint.com/batch_sc ... e_time.htm
Once you've written a batch script that does the right thing, have your plugin call that instead of the check_logfiles command directly.
Hope that helps!
set /a DT = 20200212
echo date is %DT%
c:\Users\Rebecca\check_logfiles.exe --logfile logfile%DT%.txt
Hope that helps!
RebeccaIlene
Thank you so much for the suggestions!
unfortunately, this does not solve the entire problem.
The file names comes with a set of random five digits with an underscore before and after the date format.
For example: 768902_14022020_86720_test.txt
In this case as the numbers do not have a pattern we would still need to use a wildcard name.
Can you please suggest what we can do in this case?
Regards,
Rebecca Murray
Regards,
Rebecca Murray
In that case, you're going to need to write a slightly more complicated script in a language that can handle two wildcards, because I don't think a bat file can do that. Cygwin or powershell should be able to handle that. The idea is the same, you're just writing a wrapper script that can figure out the filename and call your log checker program against it.
You might be able to get what you want in a bat file by trying to pass the filename in with
...but someone with more expertise in bat files than I have would have to chime in here with the specifics.
As a shell script in cygwin, it's super simple:
This is a bit beyond the scope of a Nagios-specific question, but I hope I've helped anyway.
dir /b | find "20200214"
#!/bin/sh
DT=`date +%Y%m%d`
LOGFILE=`ls logfile_*_*_*.log | grep $DT`
/cygdrive/c/Users/Rebecca/check_logfiles.exe --logfile $LOGFILE
