session timed out in schedule reports
kn00567386
I am scheduling metric CPU and memory report in PDF. But i do receive PDF file with no data in it. I only see report name and 'session timed out' string in PDF file. I have optimized php settings but there is no success. I have uploaded httpd and wkhtmltox logs for reference.please help.
There is another issue when i try to download capacity planning report for all hosts, nagios portal does not responds i observed CPU goes 100% for wkhtmltox process and dont finish till we kill it.
benjaminsmith
Re: session timed out in schedule reports
Hello @kn00567386,
To clarify, did you follow our directions below to optimize the PHP settings?
https://support.nagios.com/kb/article/n ... e-611.html
Can you send us your system profile to help troubleshoot? You may be running out disk space or system resources. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
kn00567386
I have messaged you profile.
yes I have already did that but no success after it.
benjaminsmith
Got your message and while looking over the profile, I noticed these entries in the Apache logs.
Lastly, can you upload or PM the empty pdf report and is this affecting all of the reports in XI. What happens when you simply download the pD of the report without scheduling it. Thanks
I would remove the # symbol ( see: https://en.wikipedia.org/wiki/INI_file#Comments).PHP Deprecated: Comments starting with '#' are deprecated in /etc/php.ini on line 1430 in Unknown on line 0
Let's check the permissionson the config.inc.php file (attach the file).PHP Fatal error: require_once(): Failed opening required '/usr/local/nagiosxi/html/includes/../config.inc.php' (include_path='.:/usr/share/pear:/usr/share/php') in /usr/local/nagiosxi/html/includes/common.inc.php on line 6, referer: https://10.65.238.201/nagiosxi/includes ... mory+Usage
ls -lR /usr/local/nagiosxi/ > /tmp/support.txt
kn00567386
@BenjaminSmith,
Please find attached empty report and file permission info.
There is no option to download reports in metrics. I am able to download capacity planing report in pdf. There is no issue.
benjaminsmith
It's interesting that this is only a problem for the metrics component. I would like to verify that the Program URl settings are correct. Can you verify that you have the correct IP address/url in Admin > System Config > System Settings > General Program Settings. Are you using http or https by default? Next, run the following tail command and force it send the schedule report and post the log.
You can send the schedule report from My Scheduled Reports.
Are you using any kind of network proxy? Thanks.
tail -Fn0 /var/log/httpd/error_log /var/log/httpd/ssl_error_log > /tmp/report.txt
benjaminsmith
One more thing. I noticed that you are running an older version of Nagios XI, and there was an issue with jquery compatibility (since been resolved). Please try opening the: /usr/local/nagiosxi/html/config.inc.php file with a text editor and add the following config option:
and then test the report again. You'll see it in the comments at the end of the file.
$cfg['old_browser_compat'] = 1;
kn00567386
Hi Benjamin,
yes IP is correct and we are using https by default, please refer attached screenshot.
I had run report after making changes in config.inc.php, but no success and i have attached logs too.
benjaminsmith
Thanks for your patience on this. It's a bug and this has been corrected in the latest version; we were able to repeat the issue on 5.5.11. Please upgrade to the latest version to resolve the error.
kn00567386
Hi benjamin,
I am facing same issue on 5.6.6 version also.
