Nagiosxi Reports pahe not loading
mccrakem
Post by mccrakem »
Hi
When I access the reports page all I get is the loading screen.
Nothing is displayed
Screenshot attached
jdunitz
Re: Nagiosxi Reports pahe not loading
Post by jdunitz »
There are a couple things that should help with this.
First, you can disable autoloading of reports on your report page. To do so, go to Admin, then on the left under System Config, click Performance Settings, go to the Auto-Running page and check the box to disable reports from auto-running.
Secondly, you may find it helpful to do some PHP configuration tuning as described in this document:
https://support.nagios.com/kb/article/n ... e-611.html
See if that makes it work better, and if not, let us know!
mccrakem
Post by mccrakem »
Hi
Thanks for that but that just stops the Reports from Auto running, as soon as I try and run any of the original installed reports the system just sits again at the previous attached screenshot
when I run the command
tail /var/log/httpd/*rror_log
the results are shown in the attached screen, nothing showing in the logs are the same that are on the link you provided
jdunitz
Post by jdunitz »
Let's continue figuring out what's going on with your system.
How many hosts and services are you monitoring?
Also, what is the content (how many hosts/services/other items) and timeframe (24 hours, a week, a month...) of the reports you're running?
Additionally, can you post or PM the following files for us to inspect?
/etc/php.ini
/etc/httpd/conf/httpd.conf
/etc/httpd/conf.d/nagiosxi.conf
/etc/httpd/conf.d/ssl.conf
Those php warnings and whatnot in the screenshot you attached aren't indicative of a problem.
We do need to see a bit more error log context, though, so please do this:
# tail -f /var/log/httpd/*error_log
While that is running, go try to load a report, give it a good ten minutes or so, and let us see the error log output during that time.
Thanks!
mccrakem
Post by mccrakem »
Hi
Sorry about this but When I logged in this morning and went to Rerport the reports ran fine
When I went to reports I was tailing the error log but it never chnaged
This was the only output - attached Screenshot
But as the Reports are now working I would not worry to much about this and close the ticket
mccrakem wrote:Hi
Glad it's working now!
Locking thread
