How to get account lookups list alphabetically?
This support forum board is for questions relating to Nagios Fusion.
dlukinski
Post by dlukinski »
Hello Nagios support
FUSION (as well as XI and LOG) account lookups (by First Last names) are not listed alphabetically, but historically.
How to change that?
- really annoying and hard to find names when there are hundreds of accounts
Thank you
cdienger
Re: How to get account lookups list alphabetically?
Post by cdienger »
Where are you looking exactly? I've done a couple tests an things seem to be ordered alphabetically so far. Can you provide a screenshot to clarify?
dlukinski
Post by dlukinski »
cdienger wrote:Where are you looking exactly? I've done a couple tests an things seem to be ordered alphabetically so far. Can you provide a screenshot to clarify?
Users should be sorted alphabetically, but are not... I filed an internal bug report on the issue (task_id=14931). The bug should be fixed in the next release of Nagios Fusion. Thank you for reporting the issue!
dlukinski
Post by dlukinski »
lmiltchev wrote:Users should be sorted alphabetically, but are not... I filed an internal bug report on the issue (task_id=14931). The bug should be fixed in the next release of Nagios Fusion. Thank you for reporting the issue!
Thank you,
Please close the case
