48 UDP Connections used for a maximum of 9 Monitors
jfarnsworth
Post by jfarnsworth »
This might be more of a SNMP question, but we have about 9 checks per node in Nagios that use SNMP. When looking at the logs, I see this:
info daemon May 10 16:41:11 <remote-node> snmpd[32187]:Connection from UDP: [<nagios-IP>]:40318->[<remote-node-IP>]:161
info daemon May 10 16:41:39 <remote-node> snmpd[32187]:Connection from UDP: [<nagios-IP>]:41334->[<remote-node-IP>]:161
info daemon May 10 16:42:28 <remote-node> snmpd[32187]:Connection from UDP: [<nagios-IP>]:51734->[<remote-node-IP>]:161
info daemon May 10 16:43:45 <remote-node> snmpd[32187]:Connection from UDP: [<nagios-IP>]:35541->[<remote-node-IP>]:161
info daemon May 10 16:43:45 <remote-node> snmpd[32187]:Connection from UDP: [<nagios-IP>]:45279->[<remote-node-IP>]:161
Our SNMP checks occur every 5 minutes, so we have close to 5 UDP connections per monitor in this 3 minute window, assuming all 9 ran. Why is it making so many connections? Shouldn't it only require one?
From what I understand, these SNMP checks come from the nagios plugins tar file, if not, let me know.
Re: 48 UDP Connections used for a maximum of 9 Monitors
Many plugins have to make numerous SNMP calls to get multiple items to order to perform the calculations to give you the final results.
jfarnsworth
Thanks, just wanted to make sure I wasn't crazy on this.
jfarnsworth wrote:Thanks, just wanted to make sure I wasn't crazy on this.
No problem
