Plugin of Nagios XI for know if a host is alive using LS ?
alopera
Post by alopera »
Ping is uses in Nagios XI for know if a host is a alive.
Sometimes the firewall block the connection.
In Nagios XI I want check if a host is alive if in the last 5 min there is logs In LS. Is possible ?
If a host answers to ping or there ir events is alive.
Regards
Re: Plugin of Nagios XI for know if a host is alive using LS
You don't need to use LS. If ICMP requests are not allowed for this host, you could change your "host alive" command to use something else, e.g. using check_tcp against a port that is open, etc.
Here's our documentation on changing the host alive check command:
https://assets.nagios.com/downloads/nag ... _In_XI.pdf
alopera
Post by alopera »
Is there a plugin Nagios XI for check the number of events/15 min (integrated to LS) of a host?
regards
benjaminsmith
Post by benjaminsmith »
Hi Alberto,
Please see PM.
Yes, you can run the Nagios Log Server Wizard, and use the "Text Queries" section
The example below will give a count for the host "192.168.5.153" and warn if over 50, critical if over 100 in the last 15 minutes
