fail2ban on nagiosxi server
dslaughter
Post by dslaughter »
IS it ok to install fail2ban on the nagiosxi server or is there something built in that provides the same function?
Re: fail2ban on nagiosxi server
dslaughter wrote:IS it ok to install fail2ban on the nagiosxi server or is there something built in that provides the same function?
I don't see any reason why this would be a problem.
dslaughter
OK, I wanted to check to be sure that it would not interfere with the nagiosxi apache config.
Lock it
dslaughter wrote:OK, I wanted to check to be sure that it would not interfere with the nagiosxi apache config.
Lock it
Locking
