Vishh
Posts: 4 Joined: Fri Dec 06, 2019 9:19 am
Post
by Vishh » Wed Feb 19, 2020 5:21 pm
Hi Guys, please help me in monitoring event ID on Nagios core.
Below command gives proper output,
libexec]$ ./check_nrpe -H Hostname -c checkeventlog -a filter="id=4231" scan-range=-5m
OK: No entries found|'count'=0;1;2[/b]
but when implemented the same on Nagios, I will get Critical alert with some Junk messages.
CRITICAL: 21 message(s) Application Microsoft-Windows-CertificateServicesClient-AutoEnrollment
Below are the service and command definition
use app-service
host_name Hostname
service_description APP - EventID-4231 Port Exhaust
check_command check_nrpe!check_eventlog!'filter=id=4231' scan-range=-5m
max_check_attempts 1
command_name check_eventlog
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a $ARG2$
Further, please find the changes made in nsclient.ini file and suggest the correct configurations for the desired output.
[/modules]
CheckEventLog=enabled
; CheckEventLog - Check for errors and warnings in the event log.
CheckEventLog = 1
[/settings/eventlog]
buffer size = 131072
debug = 0
lookup names = 1
[/settings/eventlog/real-time]
enabled = true
log=application,system
startup age=30m
filter=id = 4231 and category = 0
Vishh on Wed Feb 19, 2020 6:19 pm, edited 1 time in total.
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Wed Feb 19, 2020 5:27 pm
You have two different arguments.
Vishh wrote: Below command gives proper output,
libexec]$ ./check_nrpe -H 10.177.60.232 -c checkeventlog -a warn=1 crit=2 filter="id=4231" scan-range=-30m
specifically I am highlighting
Now here you are defining:
Vishh wrote: Below are the service and command definition
use assetpoint-app-service
host_name papxi05
The reason why the service is giving different results to your command line test is because they are not the same.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
