snmp traps message not showing in nagios ...
xpertech
Post by xpertech »
We refer document "Integrating_SNMP_Traps_With_Nagios_XI.pdf" to test snmp traps on NagiosXI, but NagiosXI seems not get the trap message?
the snmptt.log did write in message, but seems didn't transfer to NagiosXI, what could be the problem?
Re: snmp traps message not showing in nagios ...
Go to the Admin > SNMP Trap Interface in XI and click on the Defined Traps tab.
Search for the LinkUp trap definition and edit it.
Is the passive section enabled and filled it for all of the fields?
See this document, page 8.
https://assets.nagios.com/downloads/nag ... h-NXTI.pdf
