service_check_timeout_state XI
warapp
Post by warapp »
Is service_check_timeout_state option available yet in XI? I've updated nagios.cfg, but, changes for this setting do not appear to be working.
Plugin timeouts still return CRITICAL despite having set service_check_timeout_state=w.
Running Nagios XI 5.4.13
Thanks for any help.
-wr
Re: service_check_timeout_state XI
Are you sure you are reaching the service_check_timeout time in seconds as opposed to a timeout limit in the plugin?
service_check_timeout_state is only affected if the service_check_timeout in the nagios.cfg is reached
warapp
Post by warapp »
The issue was that the plugin timeout was set to the same value as the service check timeout value. As soon as I increased the plugin timeout value to be greater than the service check timeout value, nagios marked the timeouts according to the service_check_timeout_state setting.
Thank you.
warapp wrote:The issue was that the plugin timeout was set to the same value as the service check timeout value. As soon as I increased the plugin timeout value to be greater than the service check timeout value, nagios marked the timeouts according to the service_check_timeout_state setting.
Thank you.
Great!
Locking thread
