Service check in Unknown state
Pratapa
Post by Pratapa »
One of the service check is in Unknown state.
Following is the check command.
[root@nagios server]# ./check_nrpe -H host1 -p 5666 -c CheckEventLog -a filter=new file=system MaxWarn=1 MaxCrit=1 filter-generated=\>5m filter+eventID=="10004" filter+eventType==error filter+eventSource==DCOM filter=in filter=all truncate=30
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
I (0.3.5.1 2008-09-24) seem to be doing fine...
What could be the problem.
host1 is the windows server.
We are using Nagios core.
Re: Service check in Unknown state
I'm not sure how you determined what string to use but your filters do not seem valid.
What do you get if you run
./check_nrpe -H host1 -p 5666 -c CheckEventLog -a file=system
Do you have CheckEventLog enabled in the .ini file?
Also, I'm not 100% sure when that was added to NSClient++ as that is not our project but the current version is 0.5.2
Here are the docs
https://docs.nsclient.org/reference/win ... kEventLog/
Pratapa
Post by Pratapa »
Following is the output we are getting.
[root@nagiosserver]# ./check_nrpe -H host1 -p 5666 -c CheckEventLog -a file=system
Pratapa
Post by Pratapa »
Pratapa wrote:Do you have CheckEventLog enabled in the .ini file?
I don't see CheckEventLog=enabled or CheckEventLog=1 in nsc.ini file
Pratapa wrote: I don't see CheckEventLog=enabled or CheckEventLog=1 in nsc.ini file
You will definitely need to add that and then restart NSClient++
Pratapa
Post by Pratapa »
We will enable CheckEventLog and let you know.
Pratapa
Post by Pratapa »
This is fixed after enabling the CheckEventLog in .ini file.
Thank you for your help.
You may lock the thread.
Pratapa wrote:This is fixed after enabling the CheckEventLog in .ini file.
Great!
Locking thread
