Failed Apply Config to show config
optionstechnology
Post by optionstechnology »
Currently when an "Apply Configuration" fails it outputs something like this-
Error: Could not register service escalation (config file '/usr/local/nagios/etc/serviceescalations.cfg', starting on line 278)
It would be great if it could actually grep the file and output the config that is causing the issue to the screen so I don't have to go to the files, find the config, and then go back into the front end to fix it
(It would also be super amazing if changes made via the API actually outputted these errors when it fails to apply)
benjaminsmith
Re: Failed Apply Config to show config
Post by benjaminsmith »
Hello @optionstechnology,
I appreciate the feedback. I'll put in a feature request on your behalf to the dev team.
