agent for HP-UX 11.31
josetorres
Post by josetorres »
Hello, i want to install nagios agent in HP-UX 11.31 but i could´nt find an agent and a linux agent isn´t compatible. Is there anyone how has that agent or what agent I could install.
Best Regards
jdunitz
Re: agent for HP-UX 11.31
Post by jdunitz »
With a bit of googling, it appears that HP and a couple other companies should have an nrpe depot for ia64 that you can just swinstall.
We can't support those directly, of course, but they do exist.
Otherwise, if you have your development environment set up on your HP machine, you can install NRPE from source.
It looks like there might be a minor patch required, as explained here:
https://cyruspy.wordpress.com/2010/05/1 ... x-11-31-2/
Hope that helps!
--Jeffrey
