NRPE Service Not Starting
amitgupta19
Post by amitgupta19 »
I have recently installed the NRPE Agent on a Linux server.
But the service is not coming up.
Any idea where to check and what needs to be checked.
Re: NRPE Service Not Starting
What does the service status show?
what OS and version is the server?
What did you perform to install NRPE?
amitgupta19
Please find here with the screenshot
Server version is Linux 7.7
Please find attached the document.
Installing_The_XI_Linux_Agent.pdf
NPRE Installation
(199.88 KiB) Downloaded 190 times
Service Status
Service Status
This document does not install NRPE in the locations you show in the service status
Are you sure you didn't also try to install NRPE from a package repository such as yum?
what is the output of the following
netstat -nlp|grep 5666
service xinetd status
amitgupta19
As i said NRPE was installed using the attached document.
Please find attached the Output of the command.
It looks like it is running properly under xinetd
From your previous screenshot you were showing the output of a nrpe service which this document wouldn't create, nor would it put the binaries in the location that service is showing, which led me to believe you (or another person with access to this server) installed NRPE from a package as well (RPM or deb package).
configuration file for nrpe running under this setup is /usr/local/nagios/etc/nrpe.cfg and you would need to reload xinetd after making changes
systemctl restart xinetd
amitgupta19
what changes should i make and where?
amitgupta19 wrote:what changes should i make and where?
That depends, what are you trying to accomplish?
Are you getting an error connecting to this server from your Nagios server?
amitgupta19
Thanks Scott for your support.
I got it.
amitgupta19 wrote:Thanks Scott for your support.
I got it.
Great
Locking thread
