Bandwidth Usage Reports Missing
trel1234
Post by trel1234 »
There are missing a number of hosts in bandwidth usage reports.
There are rrd files for the hosts, the hosts are listed under the "View Report For" however they are missing under the "See all available reports"
The bandwidth graphs are filling up with data, and the usage looks normal, and are otherwise operating normally.
I have run through the php optimization article https://support.nagios.com/kb/article/n ... e-611.html however this has not resolved the issue. I am not seeing anything when running:
tail -f /var/log/httpd/*error_log
Running any manual mrtg commands produces the desired result for any of the services that are missing from bandwidth usage reports.
I'll post the nagios profile file via IM.
Thanks in advance.
Re: Bandwidth Usage Reports Missing
It is probably a permission issue with the MRTG rrd files. Run the following as root to set the permissions.
chown apache:nagios /etc/mrtg -R
chmod 775 /etc/mrtg -R
chown apache:nagios /var/lib/mrtg -R
chmod 775 /var/lib/mrtg -R
Restart Apache
service httpd restart.
Log out of the GUI and back in, do you see all of the devices and ports?
trel1234
Post by trel1234 »
The permissions appear to be correct, here are the
# ls -lash | grep -v 'apache nagios'
total 1013M
4.0K drwxr-xr-x. 36 root   root   4.0K Sep 19 11:26 ..
   0 -rw-r--r--   2 nagios nagios    0 Mar  2 09:30 mrtg.lock
   0 -rw-r--r--   2 nagios nagios    0 Mar  2 09:30 mrtg.lock_60858
# ls -lash | grep -v '\-rw\-rw\-r\-\-'
total 1013M
552K drwxrwxr-x.  2 apache nagios 548K Mar  2 09:30 .
   0 -rw-r--r--   1 nagios nagios    0 Mar  2 09:30 mrtg.lock
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 20:20 mrtg.lock_10011
   0 -rwxrwxr-x   1 apache nagios    0 Jan 16 21:25 mrtg.lock_10035
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 00:35 mrtg.lock_11464
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 03:35 mrtg.lock_12485
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 22:35 mrtg.lock_12787
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 06:50 mrtg.lock_14205
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 04:55 mrtg.lock_16757
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 23:20 mrtg.lock_20067
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 03:25 mrtg.lock_22901
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 06:40 mrtg.lock_23024
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 09:40 mrtg.lock_23911
   0 -rwxrwxr-x   1 apache nagios    0 Nov  5 03:50 mrtg.lock_23935
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 01:05 mrtg.lock_24443
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 23:55 mrtg.lock_2518
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 08:25 mrtg.lock_27688
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 05:25 mrtg.lock_29683
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 16:45 mrtg.lock_30212
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 19:45 mrtg.lock_30599
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 07:35 mrtg.lock_31929
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 08:40 mrtg.lock_3204
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 10:55 mrtg.lock_38751
   0 -rwxrwxr-x   1 apache nagios    0 Nov  5 06:20 mrtg.lock_41794
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 01:15 mrtg.lock_44340
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 02:05 mrtg.lock_47199
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 07:50 mrtg.lock_47399
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 04:20 mrtg.lock_47762
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 10:15 mrtg.lock_48877
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 17:15 mrtg.lock_49486
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 20:55 mrtg.lock_52457
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 00:35 mrtg.lock_53357
   0 -rwxrwxr-x   1 apache nagios    0 Nov  5 04:30 mrtg.lock_58222
   0 -rwxrwxr-x   1 apache nagios    0 Jan 21 04:45 mrtg.lock_58359
   0 -rwxrwxr-x   1 apache nagios    0 Nov  5 03:15 mrtg.lock_59610
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 09:55 mrtg.lock_61696
   0 -rwxrwxr-x   1 apache nagios    0 Nov  5 05:50 mrtg.lock_6393
   0 -rwxrwxr-x   1 apache nagios    0 Nov 18 18:50 mrtg.lock_685
   0 -rwxrwxr-x   1 apache nagios    0 Nov 19 05:35 mrtg.lock_7136
   0 -rwxrwxr-x   1 apache nagios    0 Nov  5 11:01 mrtg.lock_7793
   0 -rwxrwxr-x   1 apache nagios    0 Jan 20 15:30 mrtg.lock_9300
   0 -rwxrwxr-x.  1 apache nagios    0 Mar  2 09:27 mrtg.ok
The permission change was run anyway, and apache was restarted and the reports are not showing up.
Reason: Profile removed and shared with the other Techs
Can you post a name of a Host and Service that is not showing up in the "See all available reports" menu?
If you login as the nagiosadmin user in the XI GUI, do you see all of the reports?
trel1234
Post by trel1234 »
I have run these commands and forwarded you these details in PM
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg -debug=cfg,base,log &> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg &>> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios &>> /tmp/mrtg.txt
{ time LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg 2>1 ; } 2>> /tmp/mrtg.txt
The ports are updating with bandwidth, however the bandwidth reports are not accumulating data in the reports, there are points where it updates and accumulates but it is not consistent.
I have also gathered the rrd files for one of the hosts and I'll send it in PM
EDIT:
I have included the screenshot of the daily bandwidth count for posterity, in order to document what is happening.
The rrd files are round robin databases and they store averaged data differently depending on how far back they go.
When the report runs for last month, is looks at the section of the RRD file that may not have all of yesterdays data in it as it has not been filled in so you may not see yesterdays data until the time the data is moved in to that section.
