storage is up and fine at the storage end but in nagios
fmomin
Post by fmomin »
storage is up and fine at the storage end but in nagios monitoring tool storage status is showing down.
Please help me for same.
Unable to ping storage ip server from nagios server.
mbellerue
Re: storage is up and fine at the storage end but in nagios
Post by mbellerue »
Does the storage server respond to pings normally? If you ping the storage server from your desktop, do you get a reply? If not, then there may be a setting on your storage server somewhere that tells it to respond to pings.
fmomin
Post by fmomin »
Could YOU please suggest me how can we resolve this issue.
fmomin
Post by fmomin »
i m suggesting that what to check from nagios end.
mbellerue
Post by mbellerue »
If Nagios cannot ping the device, then you can change the Host check. Go to Configure -> Core Config Manager -> Hosts -> Select the host in question
Change the Check Command to another check type. You can set it to something like check_dummy and put 0 in $ARG1$. That will mean that the host is always OK. But that means you need to pay particular attention to your service checks for that host.
