1. Redhat 5
2. 64bit
3. Manual Install
4. SSL yes, otherwise no other special configuration
Hi.
I setup WMI on couple Windows servers and the main problem is with monitoring CPU Usage.
I am using latest WMI package abailable for download 1.49.
On Windows 2003 server (physical or VM) it show in Status Information:
On Windows 2008 server (physical or VM) it show in Status Information:UNKNOWN - The WMI query had problems. The target host (xxx.xxx.xxx.xxx) might not have the required WMI classes installed. This can happen, for example, if you are trying to checkiis but IIS is not installed. It can also happen if your version of Windows doe
But on Performance Graphs page:OK (Sample Period 900 sec) - Average CPU Utilisation Need at least 2 WMI samples%
No performance graphs were found for this service.
