gearman error
progressive.nagiosXI
gearman error
Post by progressive.nagiosXI »
hi team,
we update nagios core and mod gearman today
we are getting below error log /var/log/gearmand/gearmand.log and disk is going full again and again ,Please help on priority
ERROR 2020-02-03 20:54:45.000000 [ main ] accept(Too many open files) -> libgearman-server/gearmand.cc:691
[root@monitoring-nagiosxi gearmand]# rpm -qa |grep -i gearman
mod_gearman-3.0.7-1.el7.x86_64
gearmand-0.33-7.x86_64
mod_gearman-debuginfo-3.0.7-1.el7.x86_64
gearmand-devel-0.33-7.x86_64
gearmand-server-0.33-7.x86_64
[root@monitoring-nagiosxi gearmand]# /usr/local/nagios/bin/nagios –help
Nagios Core 4.4.5
Last Modified: 2019-08-20
License: GPL
Re: gearman error
Post by Box293 »
What procedure did you use to upgrade?
Re: gearman error
Find the systemctl file that loads the gearman daemon.
find / -name gearmand.service
Typically it could be in this folder.
/etc/systemd/system/multi-user.target.wants/gearmand.service
Add this line in the file
LimitNOFILE=50000
After the following section
[Service]
Save the file and run this as root
systemctl daemon-reload
then run this
systemctl restart gearmand
Look at the gearmand.log file to see if the error is gone.
You may also have to increase the linux kernel open file limit.
Edit this file
/etc/security/limits.conf
Add this to the bottom
* hard nofile 1000000
* soft nofile 1000000
Reboot the server.
Which file or folder has the data that is filling up the drive?
Re: gearman error
Hi ,
Thanks tgriep ,
after given changes and observe for 60 min we are not getting below error in /var/log/gearmand/gearmand.log which filled disk 2GB/min.
but now we are getting below error in /var/log/gearmand/gearmand.log
[root@monitoring-nagiosxi gearmand]# tail -f  gearmand.log
  ERROR 2020-02-04 17:30:52.000000 [     3 ] lost connection to client recv(EPIPE || ECONNRESET || EHOSTDOWN)(Connection reset by peer) -> libgearman-server/io.cc:100
  ERROR 2020-02-04 17:30:52.000000 [     3 ] closing connection due to previous errno error -> libgearman-server/io.cc:109
  ERROR 2020-02-04 17:30:52.000000 [     2 ] lost connection to client recv(EPIPE || ECONNRESET || EHOSTDOWN)(Connection reset by peer) -> libgearman-server/io.cc:100
  ERROR 2020-02-04 17:30:52.000000 [     2 ] closing connection due to previous errno error -> libgearman-server/io.cc:109
  ERROR 2020-02-04 17:31:16.000000 [     2 ] lost connection to client recv(EPIPE || ECONNRESET || EHOSTDOWN)(Connection reset by peer) -> libgearman-server/io.cc:100
  ERROR 2020-02-04 17:31:16.000000 [     2 ] closing connection due to previous errno error -> libgearman-server/io.cc:109
Re: gearman error
Those errors may be coming from a worker that cannot connect to the gearman server so run the gearman_top command and verify that all of the workers are in there, if any missing workers, look there.
Or it is a module.conf setting on the gearman server or a setting in one of the worker.conf files on a worker.
I would have to see them to check the settings and well as the output of this command ran on the Nagios sever.
gearman_top -b
Re: gearman error
All details attached and shared in PM ==> tgriep
1) gearman server -module.conf
2)gearman_top -b
3)hostgroup where Jobs Waiting is highest - worker.conf attached
Re: gearman error
Edit the worker.conf file and increase this option
min-worker=50
to
min-worker=250
Restart the Mod Gearman worker on that server.
Run the gearman_top command and see if it starts to process more checks.
If not, edit the worker file and enable debugging.
debug=2
Then check this log for errors.
/var/log/mod_gearman2/mod_gearman_worker.log
