Alerts are not generating from nagios to pager duty
srivemp1
Post by srivemp1 »
Alerts are not generating from Nagios to particular pager duty from where alerts are not notifying to slack channel.
To different pagerduty group it is able to send alerts.
From pager duty when I tried to send one incident its working fine.
Please guide me how to resolve this issue.
Re: Alerts are not generating from nagios to pager duty
What document/guide/tutorial did you follow in order to integrate PagerDuty to Nagios XI? Can you provide us with a URL to the document?
Show us a screenshot of the State History report, showing a host or a service in a hard non-OK state.
Also, show us a screenshot of the Notifications report for the same time period, limiting the results to this particular host or service.
PM me your latest profile (Please don't post the profile.zip on the public forum).
Admin > System Config > System Profile > Download Profile
srivemp1
Post by srivemp1 »
Weird thing is after jan 21st alerts were not generating and suddenly 3days alert came but later alerts are not generating.
Mar  5 02:47:11 nagmonm101 nagios: SERVICE NOTIFICATION: vikoth18;sartmongo2.fringe.ibm.com;/ Disk Usage;WARNING;xi_service_notification_handler;/var/lib/kubelet/pods/93241b95-1138-4ebb-8f61-ff89a92f965c/volumes/kubernetes.io~secret/nfs-client-provisioner-token-nxs59: 0%used(0MB/7942MB) /var/lib/docker/containers/9813ea0fb52bd2251fe11e60542e2acb2596bc013eaeca99df6a071c0885c9b1/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/ec6c0783-06e8-4eac-8ab2-90abb9e6303c/volumes/kubernetes.io~secret/sart-ui-tls-key: 0%used(0MB/7942MB) /var/lib/kubelet/pods/e9818821-9f93-46d3-89c2-17f96da9dc28/volumes/kubernetes.io~secret/prometheus-operator-operator-token-9ks22: 0%used(0MB/7942MB) /var: 83%used(21212MB/25590MB) /dev/shm: 0%used(0MB/7942MB) /var/lib/kubelet/pods/8aeb3f01-298f-44c1-9d31-d98e43050509/volume-subpaths/pvc-03133821-b3fb-402f-9c07-c2b7ac6f2dd2/sart/1: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/9c5abfe2-4a57-4ef2-9f00-5a9d0cb6577f/volumes/kubernetes.io~secret/sart-ui-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/0b31570b-2c7d-444a-92c5-f591c3cad178/volumes/kubernetes.io~secret/default-token-5pzqz: 0%used(0MB/7942MB) /var/lib/kubelet/pods/d8396964-b83e-4272-a2d8-1904e2f2a0de/volumes/kubernetes.io~secret/nginx-ingress-serviceaccount-token-7zltg: 0%used(0MB/7942MB) /var/lib/kubelet/pods/7f845a1b-74d5-44bc-b92c-70d6a793380e/volumes/kubernetes.io~secret/tiller-token-gwrwn: 0%used(0MB/7942MB) /var/lib/kubelet/pods/9c5abfe2-4a57-4ef2-9f00-5a9d0cb6577f/volume-subpaths/sart-ui-tls-key/sart-ui/1: 0%used(0MB/7942MB) /var/lib/kubelet/pods/60c487ce-e529-4198-8902-50a914adf926/volumes/kubernetes.io~secret/heapster-token-9lsnr: 0%used(0MB/7942MB) /var/lib/kubelet/pods/57616425-0463-4139-a346-708337a009f8/volumes/kubernetes.io~secret/prometheus-operator-kube-state-metrics-token-zfthv: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~nfs/pv-sart-artifacts-dev: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/3985e95c-9cc7-4441-9100-e8611041a4e5/volumes/kubernetes.io~secret/default-token-m9twg: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volume-subpaths/sart-db-tls-crt/sart-api/2: 0%used(0MB/7942MB) /var/lib/kubelet/pods/279c05eb-56a5-4d59-a897-cbbb93634823/volumes/kubernetes.io~secret/default-token-5pzqz: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~secret/sart-db-tls-ca: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~secret/default-token-vjm2t: 0%used(0MB/7942MB) /sys/fs/cgroup: 0%used(0MB/7942MB) /var/lib/docker/containers/e8a52eacc73ffa9c29a69ec9ed1a53c2343d8a806a84893d3dd135eedaf85ef2/mounts/shm: 0%used(0MB/64MB) /var/lib/docker/containers/ca8948b86c5c6c90e7419161a921a55c156ac4af799def9a097f54ad9c3a0bdd/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~secret/sart-api-tls-key: 0%used(0MB/7942MB) /var/lib/kubelet/pods/61fe3225-57cd-43d8-8a3d-a848bb0a6d51/volumes/kubernetes.io~secret/ldap: 0%used(0MB/7942MB) /var/lib/docker/containers/86e93d5866d7d6c4df1288c27a5835727934914135fa660f2243f3cbfc7c8496/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/662f187c-f72a-401e-a75b-f8ff76439136/volumes/kubernetes.io~secret/sart-ui-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volume-subpaths/sart-db-tls-ca/sart-api/4: 0%used(0MB/7942MB) /var/lib/docker/containers/d859000313e890eea4b590a5e28bc9674dcd14dbb58606be81319c07d5d890c5/mounts/shm: 0%used(0MB/64MB) /var/lib/docker/containers/a0ff04723a93a3d2bd3c9086847394406f6fa6133bc5725263bd6238d32686d2/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volume-subpaths/sart-db-tls-ca/sart-api/4: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volume-subpaths/pv-sart-artifacts-dev/sart-api/5: 40%used(51538MB/127950MB) /var/lib/docker/containers/ab174f5800a212fb2395508092805e927545881b656ee7d4eb8f99e59c63afd4/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/e9818821-9f93-46d3-89c2-17f96da9dc28/volumes/kubernetes.io~secret/tls-proxy-secret: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volume-subpaths/sart-api-tls-key/sart-api/1: 0%used(0MB/7942MB) /var/lib/kubelet/pods/8aeb3f01-298f-44c1-9d31-d98e43050509/volumes/kubernetes.io~nfs/pvc-03133821-b3fb-402f-9c07-c2b7ac6f2dd2: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/76f82401-594a-481d-836d-f280ab6fede8/volumes/kubernetes.io~secret/flannel-token-k8wth: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volume-subpaths/sart-db-tls-key/sart-api/3: 0%used(0MB/7942MB) /var/lib/kubelet/pods/61fe3225-57cd-43d8-8a3d-a848bb0a6d51/volumes/kubernetes.io~secret/prometheus-operator-grafana-token-pf6hh: 0%used(0MB/7942MB) /var/lib/kubelet/pods/524c71c3-40bc-4e40-98ad-e23df09d7a7c/volumes/kubernetes.io~secret/metrics-server-token-cbqgr: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volume-subpaths/sart-api-tls-key/sart-api/1: 0%used(0MB/7942MB) /var/lib/docker/containers/9c13dc91031c2f39e0d9f2cbd3014da188dce9e97b86a8a55d658ae6e265d1a4/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/ec6c0783-06e8-4eac-8ab2-90abb9e6303c/volumes/kubernetes.io~secret/default-token-8vs6l: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volume-subpaths/sart-api-tls-crt/sart-api/0: 0%used(0MB/7942MB) /var/lib/kubelet/pods/bfba97f0-46c7-4586-a88c-49e9223df1bc/volumes/kubernetes.io~secret/config-volume: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~secret/sart-api-tls-key: 0%used(0MB/7942MB) /var/lib/kubelet/pods/61fe3225-57cd-43d8-8a3d-a848bb0a6d51/volume-subpaths/sc-dashboard-provider/grafana/4: 83%used(21212MB/25590MB) /var/lib/docker/containers/d8eebfaf71024d5d055d643e0fc4094d36347099c2ef3f57308c85658c80b9e1/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/662f187c-f72a-401e-a75b-f8ff76439136/volume-subpaths/sart-ui-tls-key/sart-ui/1: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~secret/sart-api-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/ea78b21d-cefb-4691-8f3f-34fbc4d5a133/volumes/kubernetes.io~secret/prometheus-operator-prometheus-node-exporter-token-8rdxv: 0%used(0MB/7942MB) /var/lib/docker/containers/fccbab23f6a64749a3682ac0cc9ef93e2d91e60bbb7fb0b8484e885d745ce22a/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~nfs/pv-sart-artifacts-stage: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/ce9c7e78-66ff-4658-bd83-041df97a0b99/volumes/kubernetes.io~secret/kube-proxy-token-dck6d: 0%used(0MB/7942MB) /boot: 31%used(314MB/1014MB) /var/lib/docker/containers/67f3ed02556f7492f3de7138694128349fe0ccaacad7ce8b2f800f4770925401/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volume-subpaths/sart-db-tls-crt/sart-api/2: 0%used(0MB/7942MB) /var/lib/kubelet/pods/bfba97f0-46c7-4586-a88c-49e9223df1bc/volumes/kubernetes.io~secret/prometheus-operator-alertmanager-token-m6jcg: 0%used(0MB/7942MB) /var/lib/kubelet/pods/9c46d507-6d6e-4081-83e8-dad134bb417b/volumes/kubernetes.io~secret/default-token-5pzqz: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volume-subpaths/sart-api-tls-crt/sart-api/0: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volume-subpaths/sart-api-tls-key/sart-api/1: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volume-subpaths/sart-db-tls-key/sart-api/3: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~nfs/pv-sart-artifacts-prod: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/9c5abfe2-4a57-4ef2-9f00-5a9d0cb6577f/volumes/kubernetes.io~secret/default-token-vjm2t: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~secret/sart-db-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/662f187c-f72a-401e-a75b-f8ff76439136/volumes/kubernetes.io~secret/sart-ui-tls-key: 0%used(0MB/7942MB) /var/lib/kubelet/pods/ec6c0783-06e8-4eac-8ab2-90abb9e6303c/volumes/kubernetes.io~secret/sart-ui-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/93241b95-1138-4ebb-8f61-ff89a92f965c/volumes/kubernetes.io~nfs/nfs-client-root: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/662f187c-f72a-401e-a75b-f8ff76439136/volumes/kubernetes.io~secret/default-token-jqzdm: 0%used(0MB/7942MB) /var/lib/docker/containers/3abff33fb702db8dda3fce1f95ce252b101604d372a3e0cff3dee9928f06b480/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/21c5591c-8118-4a9d-8ecb-40aea2bd4ddc/volume-subpaths/apm-server-config/apm-server/0: 83%used(21212MB/25590MB) /run: 3%used(222MB/7942MB) /var/lib/kubelet/pods/21c5591c-8118-4a9d-8ecb-40aea2bd4ddc/volumes/kubernetes.io~secret/default-token-5pzqz: 0%used(0MB/7942MB) /var/lib/kubelet/pods/9c5abfe2-4a57-4ef2-9f00-5a9d0cb6577f/volume-subpaths/sart-ui-tls-crt/sart-ui/0: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~secret/default-token-8vs6l: 0%used(0MB/7942MB) /var/lib/kubelet/pods/0b31570b-2c7d-444a-92c5-f591c3cad178/volume-subpaths/apm-server-config/apm-server/0: 83%used(21212MB/25590MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~secret/sart-db-tls-ca: 0%used(0MB/7942MB) /var/lib/docker/containers/edb189dab66ec9504f9336608f641c576be4575426244609068755d3c01c0ce4/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volume-subpaths/pv-sart-artifacts-prod/sart-api/5: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/9c5abfe2-4a57-4ef2-9f00-5a9d0cb6577f/volumes/kubernetes.io~secret/sart-ui-tls-key: 0%used(0MB/7942MB) /var/lib/docker/containers/d056d829b3891b8f6f9bf4d8e2e8aff455b0a8643767de44f07763f65401a58f/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/ec6c0783-06e8-4eac-8ab2-90abb9e6303c/volume-subpaths/sart-ui-tls-key/sart-ui/1: 0%used(0MB/7942MB) /var/lib/kubelet/pods/d82764cf-9bf6-4d2c-ba03-a8387fb94a0d/volumes/kubernetes.io~secret/coredns-token-46p9b: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~secret/sart-db-tls-key: 0%used(0MB/7942MB) /opt: 2%used(120MB/5110MB) /var/lib/docker/containers/6832315ab3ca18bfbf303c4b8e3457116137b84753a044786fd12c0fdbc96932/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/8aeb3f01-298f-44c1-9d31-d98e43050509/volumes/kubernetes.io~nfs/pvc-46efeb51-0112-455d-bfc1-60ea871dc7e2: 40%used(51538MB/127950MB) /var/lib/docker/containers/a0aed341e889b22398449260f78176b116a8e01823374f4c32261af3c6bdfa70/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/61fe3225-57cd-43d8-8a3d-a848bb0a6d51/volume-subpaths/config/grafana/0: 83%used(21212MB/25590MB) /var/lib/kubelet/pods/662f187c-f72a-401e-a75b-f8ff76439136/volume-subpaths/sart-ui-tls-crt/sart-ui/0: 0%used(0MB/7942MB) /var/lib/docker/containers/601f5b5752acc4a918d388350f822c20e16f4b7087663fa10c3cc41025986c06/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~secret/sart-api-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/8aeb3f01-298f-44c1-9d31-d98e43050509/volume-subpaths/pvc-46efeb51-0112-455d-bfc1-60ea871dc7e2/sart/0: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~secret/sart-api-tls-key: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volume-subpaths/sart-db-tls-key/sart-api/3: 0%used(0MB/7942MB) /var/lib/kubelet/pods/252e4e64-ddc8-45a9-8958-51b9b9e06314/volumes/kubernetes.io~secret/controller-token-fjq4h: 0%used(0MB/7942MB) /var/lib/docker/containers/70a0cb0ac1ed82a743f08b0ce1b011280ff5020125e75ac5b39a97d64818385a/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/9c46d507-6d6e-4081-83e8-dad134bb417b/volumes/kubernetes.io~nfs/pvc-718b9dde-0529-48e2-b422-6a5d3d409f51: 40%used(51538MB/127950MB) /var/lib/docker/containers/6c138598d8f52816b9bcb401022b35035f58ae6fd8535b14e8fbff71af88f088/mounts/shm: 0%used(0MB/64MB) /var/lib/docker/containers/2367b0d0420b7d00a393c58cf2d59f4dc7587ace810e5c474d45386c02a44d6a/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~secret/sart-db-tls-ca: 0%used(0MB/7942MB) /var/lib/docker/containers/b4212530fbd84f4be5f552b61d4dd2e9cfc55ee2eacca224cef2c54d72143664/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volume-subpaths/sart-db-tls-crt/sart-api/2: 0%used(0MB/7942MB) /var/lib/kubelet/pods/669cd0b1-ce86-443e-9282-76600bf8eb75/volumes/kubernetes.io~secret/speaker-token-7vsz4: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volume-subpaths/pv-sart-artifacts-stage/sart-api/5: 40%used(51538MB/127950MB) /var/lib/kubelet/pods/499ad366-baed-4b80-95c2-21936e332fcd/volumes/kubernetes.io~secret/default-token-5pzqz: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~secret/sart-db-tls-key: 0%used(0MB/7942MB) /var/lib/docker/containers/4c567d961033897b0293157fe894eb404369d8b5858e68e0a87aedab08fe641c/mounts/shm: 0%used(0MB/64MB) /var/lib/docker/containers/a70cd643c86c85cc29aa50b6029910e7ad714d73000e4b471a3a198de8a26346/mounts/shm: 0%used(0MB/64MB) /var/lib/docker/containers/ab9174dcfe8dee4195e56e0ac12678996f91882346691bb5cce3ec7b5235e3ff/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/ec6c0783-06e8-4eac-8ab2-90abb9e6303c/volume-subpaths/sart-ui-tls-crt/sart-ui/0: 0%used(0MB/7942MB) /var/lib/docker/containers/28b2f14d81ae55f948830ffe9543840ebda228211d0bf9332d189884f6db04ee/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~secret/default-token-jqzdm: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volumes/kubernetes.io~secret/sart-db-tls-key: 0%used(0MB/7942MB) /var/lib/kubelet/pods/61fe3225-57cd-43d8-8a3d-a848bb0a6d51/volume-subpaths/ldap/grafana/1: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volumes/kubernetes.io~secret/sart-db-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/8aeb3f01-298f-44c1-9d31-d98e43050509/volumes/kubernetes.io~secret/default-token-vjm2t: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~secret/sart-api-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/b07c20e2-eb8e-4dfd-a137-494248549653/volumes/kubernetes.io~secret/sart-db-tls-crt: 0%used(0MB/7942MB) /var/lib/kubelet/pods/72ebe464-829d-45d4-89e0-a314d4718458/volume-subpaths/sart-db-tls-ca/sart-api/4: 0%used(0MB/7942MB) /var/lib/docker/containers/a17b9330c9c61a3c3c50c26a965a29a8122d83015bc156e6911a393e147ec987/mounts/shm: 0%used(0MB/64MB) /var/lib/docker/containers/60b77645aa7628c19f0835f6951a0b6e729c512e6f21429c8c312d4f09b5d092/mounts/shm: 0%used(0MB/64MB) /: 6%used(3136MB/51190MB) /var/lib/docker/containers/99372055d58aca01fd6430f316c0c1afc863029268aada1a5f818f7a819d509e/mounts/shm: 0%used(0MB/64MB) /var/lib/kubelet/pods/b6fe0c94-91fa-4f39-852f-6c325998e6ec/volume-subpaths/sart-api-tls-crt/sart-api/0: 0%used(0MB/7942MB) (>80%) : WARNING
URL: https://www.pagerduty.com/docs/guides/n ... ion-guide/
and sent you system profile in pmx
What is the name of the host (or the service) that you haven't received notifications about?
I asked for the following:
I don't see any screenshots of the reports (State History and Notifications)...
Also, you didn't send me the profile.zip file as requested. You must have clicked on the "View System Info" button instead of "Download Profile". We need the actual file (profile.zip), so that we can review your configuration files, and your logs.
