NCPA 2.2.1 regex match service status bug in check mode
Tanel
Post by Tanel »
NCPA agent has an internal error when checking for service status in the regex match mode.
Service Filter: ^ssh$|^sshd$
Filter Settings: regex match
You can test it straight from the NCPA GUI on Ubuntu/Centos
As soon as you tick the Run as Nagios check checkbox, the agent gets an internal server error.
Same results with check_ncpa.
Re: NCPA 2.2.1 regex match service status bug in check mode
I was able to recreate the issue, and filed a bug report on GitHub:
https://github.com/NagiosEnterprises/ncpa/issues/620
Thank you for reporting it!
