I have a mysqlbinlog command that runs on a continuous basis. The basic idea is found here: https://www.percona.com/blog/2012/01/18 ... sqlbinlog/
Since this is a command and not a daemon/service that is running, please advise on the best way to monitor it with Nagios?
Monitoring of mysqlbinlog command
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Monitoring of mysqlbinlog command
It sounds like check_procs will do what you want. It doesn't matter if it's a daemon or a process started some other way--if it's running, not running, running the wrong number of instances, etc., you can watch for it.
https://nagios-plugins.org/doc/man/check_procs.html
Hope that helps!
--Jeffrey
Hope that helps!
--Jeffrey
