We are trying to monitor a CISCO 9400 switch (V 16.09.03) in Nagios. We need to monitor the status of the cards. For this, we use the following script "./check_snmp_environment.pl -2 -H 192.168.100.3 -C public -T ciscoSW" but it returns the error:
Card slot 7status Not specified, Card slot 1status Not specified, Card slot 14status Not specified, Card slot 11status Not specified, Card slot 4status Not specified, Card slot 9status Not specified, Card slot 13status Not specified, Card slot 8status Not specified, Card slot 2status Not specified, Card slot 12status Not specified, Card slot 3status Not specified, : 0/11 cards OK, 9 modules OK : CRITICAL”
We are using the CISCO-ENVMON-MIB MIB but it still does not work (the part of the modules if verified correctly)
Does anyone know what may be happening?
Thank you!
Problem to monitor cards in cisco 9400
check_snmp_environment.pl- (95.39 KiB) Downloaded 159 times
- Box293
- Too Basu
Re: Problem to monitor cards in cisco 9400
The plugin may not support the cards in the switch or perhaps the cards are on a different OID.
Have you tried the other cisco checks instead of cicsoSW like cisco and ciscoNEW ?
