Pie charts still mangled
hhlodge
Post by hhlodge »
Now on 2.4 but this is still broken. I thought this was to be fixed long ago.
- Kyle
Re: Pie charts still mangled
Kyle,
I just reopened the bug report - you can view it here:
http://tracker.nagios.com/view.php?id=177
Thanks for the feedback!
arnab.roy
Post by arnab.roy »
Yup I dont think this was ever fixed!
It wasn't, a different error was fixed, regarding graphs not displaying at all, but this has different roots. I'm not certain yet if this library has the ability to shift labels, and currently they display in the middle of their section of the pie. This looks fine when you have large pie sections, but with thin sections you have too many labels competing for the space.
arnab.roy
Post by arnab.roy »
Hi Scott,
I had posted this sometime back and Mike's response was http://support.nagios.com/forum/viewtop ... =16&t=3149 here. I had told Mike about the limitation about the labels not being able to move. Cant we use the highcharts api instead as the code is already their within the graphexplorer code? Which is better in terms of looks and works extremely well.
Cheers
Arnab
I am attaching a file that I believe will resolve this.
unzip and place in
/usr/local/nagiosxi/html/reports/availability.php
Also, new graph in 2012 release should be fixed with this patch as well
arnab.roy
Post by arnab.roy »
Now the labels are covering the text Averge Service Availability :(
Here's another version rotating the pie 45 degrees to shift the labels
hhlodge
Post by hhlodge »
Looks good! Thank you.
- Kyle
