Nagios LOG unable to read log files in Windows
dlukinski
Post by dlukinski »
We are getting this error instead of the LOG files being shipped:
{"EventTime":"2020-03-10 22:32:01","Hostname":"ZZZZZZZZZZZ","SeverityValue":4,"Severity":"ERROR","SourceName":"nxlog-ce","ProcessID":5724,"ErrorCode":720005,"EventReceivedTime":"2020-03-10 22:32:01","SourceModuleName":"internal","SourceModuleType":"im_internal","message":"failed to open D:\\Test\\test_std\\WEB-INF\\logs\r\nAccess is denied. "}
SYSTEM has full rights to the folder, how ot make nxlog read the files?
Re: Nagios LOG unable to read log files in Windows
Post by Box293 »
In your config I believe you need to define the full path to the actual log file and not a directory.
This forum post seems to be similar to your issue.
https://support.nagios.com/forum/viewto ... 10#p169306
dlukinski
Post by dlukinski »
Box293 wrote:In your config I believe you need to define the full path to the actual log file and not a directory.
How this could possibly work for logging?
- with files, created daily and having various extension naming conventions?
This really makes Nagios LOG useless
You can use wildcards in for the file name
See:
http://nxlog-ce.sourceforge.net/nxlog-d ... ml#im_file
dlukinski
Post by dlukinski »
scottwilkerson wrote:You can use wildcards in for the file name
See:
Still does work in any capacity
Ok, in the CCM Services look for this config name
3ds-app40_53.40
edit the service /log Usage
You will find it has the following hostgroup attached
3DS TATA IDC  Bangalore
This hostgroup contains the hosts you are looking for
dlukinski
Post by dlukinski »
scottwilkerson wrote:Ok, in the CCM Services look for this config name
3ds-app40_53.40
This last one must be from another Forum Post - does not apply to us
Please close this thread (we found the resolution for now)
3ds-app40_53.40
Great!
Locking thread
