We want to monitor the CPU and memory utilization by particular process on Linux environment.
I have tried getting cpu and memory utilization by using plugin check_snmp_process_wizard.pl.
[tcadmin@1691398-prd-tc1 bin]$ /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <host_ip> -C public -r -n tcadmin -m 100,200
I am getting error ERROR: Alarm signal (Nagios time-out).
Can you please explain where I am going wrong.
Re: CPU and memory utilization by particular process on Linu
Is this server using SNMP version 2c?
Try
Try
/usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <host_ip> -C public -r -n tcadmin -m 100,200 -2Re: CPU and memory utilization by particular process on Linu
Do you have an SNMP daemon listening on the machines you want to monitor? And do you have the snmpd.conf file on those machines configured correctly?
This may help, if you haven't seen it:
https://assets.nagios.com/downloads/nag ... g-SNMP.pdf
This machine we have has the SNMPd running:
This one does not:
If you do have the daemon running, but the protocol version doesn't match, you're pointed to the wrong port, the community string isn't right, or something is blocking SNMP traffic, you might still get that error.
Does that help?
# /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H 192.168.0.4 -C community -r -n sshd -m 100,200 -2
1 process named sshd (> 0), Mem : 5.2Mb OK
[root@localhost scripts]# /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H 192.168.0.2 -C community -r -n sshd -m 100,200 -2
Does that help?
Thanks for the document provided. I have installed snmp by the steps mentioned in document. I have installed snmp v2c.
firewall is inactive. snmpd.service demon is active and running.
still I am getting same error "ERROR: Alarm signal (Nagios time-out)"
[root@1691398-prd-tc1 libexec]# /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <linux_host_ip> -C public -r -n top -m 100,200 -2
[root@1691398-prd-tc1 libexec]# /usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <linux_host_ip> -C community -r -n top -m 100,200 -2
[root@1691398-prd-tc1 snmp]# cat snmpd.conf
rocommunity Str0ngC0mmunity <Nagios_Ip>
- Box293
- Too Basu
You can perform an nmap scan to see if that port is open to that server. Run this command on your XI server:
Where xxx is the address of the SNMP device.
nmap -Pn -sU -p U:161 xxxAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
