[SOLVED] NagiosXI does not show graphic
sincorchetes
Post by sincorchetes »
Hello all,
I made a script to graphic that I get an int value like 200.
I have this in conditional into script to notify a Nagios state:
ok=0
critical=1
warning=2
if [ "${resultado}" > "$5" ]; then
  echo "CRITICAL: Score is ${result} | 'score'=${result};100;110;;;"
  exit ${critical}
elif [ "${resultado}" == "$4" ]; then
  echo "WARNING: Score is too low ${result} | 'score'=${result}50;100;;;"
  exit ${warning}
elif [ -z "${resultado}" ]; then
  result=0
  exit ${critical}
else
  echo "OK: Score is ${result} | 'score'=${result};120;5000;;;"
  exit ${ok}
fi
I get correctly status, message... in NagiosXI and Nagios Core but I don't give graphics.
In NagiosXI, I have perform_data enabled, but rrd never is generated. Why It does not work?
Cheers.
EDIT: I removed ";;;" from echo lines and It's solved.
Álvaro Castillo
System Administrator
Blog: https://echemosunbitstazo.es
Twitter: https://twitter.com/sincorchetes
Re: [SOLVED] NagiosXI does not show graphic
Great!
Locking thread
