Remove Customer Support Guy with Headsets
metzlers
Post by metzlers »
I have a silly question, but I was asked to find out, how can we remove the guy with the headsets in the We're Here To Help on the front page of Nagios XI. I was asked to change his picture to reflect our support team.
Thank you,
Shane Metzler
Re: Remove Customer Support Guy with Headsets
Since I am the guy whom you are trying to remove, let me answer... :)
There are two files in the "/usr/local/nagiosxi/html/images" directory - techsupport-splash.png and techsupport-splash2.png. You can drop your custom image in that directory and replace both files with it.
cd /usr/local/nagiosxi/html/images
Make sure the resolution of your image is about the same as the one of the "original" images, and the files are owned by nagios with 644 permissions.
Keep in mind that your custom image would be overwritten on every upgrade of Nagos XI, so you would need to repeat the process.
Hope this helps.
smetzler
Post by smetzler »
Thank you so much for the update!
smetzler wrote:Thank you so much for the update!
May we lock this thread?
ssax
Dreams In Code
Post by ssax »
Alternatively, you can go to Admin > Custom Includes > Images tab and upload your pics you want.
Then create a replaceludmil.css file in a new file on your workstation:
- Change the YOURIMAGE.png to the actuall name of your pic you uploaded
.ts-splash { background: url('/nagiosxi/includes/components/custom-includes/images/YOURIMAGE.png') no-repeat; }
.ts-splash:hover { background: url('/nagiosxi/includes/components/custom-includes/images/YOURIMAGE2.png') no-repeat; }
Then upload it in Admin > Custom Includes > CSS, check the box next to it, and click the Save Change button.
This should survive upgrades.
smetzler
Post by smetzler »
Thank you everyone for the help! I was able to change the picture with the first suggestion. Unfortunately the css script did not work but I have not had time to play with it yet.
Shane Metzler, MSCy, GCFE
smetzler wrote:Thank you everyone for the help! I was able to change the picture with the first suggestion.
Great!
Locking thread
