check_snmp_mem not an available "check command"
boeingcccs2
Post by boeingcccs2 »
In version 5.4.10 I created a service check using the check command check_snmp_mem. In 5.6.10 I am unable to import this service configuration due to error "Service check command 'check_snmp_mem .... not found anywhere". In the core config management service management GUI this check is no longer available in the "check command" drop down. It does exist under /usr/local/nagios/libexec and I can execute it from the command line. How can I use this check command?
Thanks!
Scott
Re: check_snmp_mem not an available "check command"
boeingcccs2 wrote:In version 5.4.10 I created a service check using the check command check_snmp_mem.
You should import the commands.cfg form the old system first
boeingcccs2
Thanks! Importing the command definition for check_snmp_mem worked. Not sure why that got removed from the default commands.cfg.
Scott
boeingcccs2 wrote:Thanks! Importing the command definition for check_snmp_mem worked. Not sure why that got removed from the default commands.cfg.
Scott
Great!
Locking thread
