I would like to know if there is an easy way to change SNMP version, for instance, from 2c to 3.
When I check on Host Management, there is nothing...See attachment.
Change SNMP version
tbs-infrastructure
Change SNMP version
Re: Change SNMP version
You would do this on the individual service checks.
the easiest thing to do if you set it up with a Wizard would be to re-run the wizard
No problemtbs-infrastructure wrote:Thanks
