VMWare plugin soap errors
cairnsd
Post by cairnsd »
Hi
I get the following error
CHECK_VMWARE_API.PL CRITICAL - SOAP request error - possibly a protocol issue: <?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
Nagiosxi 5.612
CentOS Linux release 7.7.1908 (Core)
Vmware 6.5
Thanks in advance
d
jdunitz
Re: VMWare plugin soap errors
Post by jdunitz »
Did this work previously and has now stopped working, or is this the first time you're setting this plugin up?
Your experience looks pretty similar to this:
https://bclary.com/blog/2014/04/17/how- ... sdk-5-5-0/
You may need to downgrade libwww-perl in this case.
Get this file and put it the /tmp folder on the nagios server.
http://search.cpan.org/CPAN/authors/id/ ... 837.tar.gz
If your Nagios server has a route to the internet, you could do that thusly:
# cd /tmp
# wget http://search.cpan.org/CPAN/authors/id/G/GA/GAAS/libwww-perl-5.837.tar.gz
Run the following as root in the Nagios server to downgrade that module.
# cd /tmp
# tar xvfz libwww-perl-5.837.tar.gz
#    cd libwww-perl-5.837
#    perl Makefile.PL -l
#    make
#  make install
Let us know if that helps!
--Jeffrey
cairnsd
Post by cairnsd »
I am setting the plugin for the first time. Shall I still need to downgrade the libperl?
d
cairnsd
Post by cairnsd »
Yes thanks that procedure did the trick ! Thanks for your help !
cairnsd wrote:Yes thanks that procedure did the trick ! Thanks for your help !
Great!
Locking thread
