rrdtraf
patalenszki.zoltan
rrdtraf
Post by patalenszki.zoltan »
Dear support.
We use check_rrdtraf for monitoring bandwiths on network devices. We got always zero for a while. Could you please help me?
I've tried to increase forks, but with no success.
# Minimal mrtg.cfg
HtmlDir: /var/www/mrtg
ImageDir: /var/www/mrtg
LogFormat: rrdtool
LogDir: /var/lib/mrtg
ThreshDir: /var/lib/mrtg
WorkDir: /var/lib/mrtg
Forks: 12
EnableSnmpV3: yes
Include: conf.d/*.cfg
EnableSNMPv3: yes
Last entries from ncpd.log is from year 2014 despite of that log_level=-1 in npcd.cfg
Re: rrdtraf
What version of Nagios XI are you running?
patalenszki.zoltan
Re: rrdtraf
5.6.9
Re: rrdtraf
Can you run the following and report any errors?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios
