Howdy all,
Well, the installer told me to post this to you. Here's what I'm getting trying to install NPRE on centos 7.
I apreciate any help you can get me.
make[1]: Leaving directory `/tmp/linux-nrpe-agent/subcomponents/nrpe/nrpe-3.2.1/src'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/etc
/usr/bin/install -c -m 644 -o nagios -g nagios sample-config/nrpe.cfg /usr/local/nagios/etc
/usr/bin/install -c -m 644 startup/default-xinetd /etc/xinetd.d/nrpe
NRPE-POST
real 3m3.039s
user 1m0.214s
sys 0m7.511s
INSTALLING EXTRA PLUGINS...
real 0m0.929s
user 0m0.001s
sys 0m0.006s
### NRPE is currently set to allow connections only from these IP addresses: ###
### 127.0.0.1 ###
### If you would like to change this list, enter all IP addresses to allow, ###
### separated by SPACES only, and then press Enter. ###
### (Put the address(es) of your Nagios XI servers(s) here.) ###
Allow from: 10.252.61.252
Failed to execute operation: Connection timed out
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
NPRE on CENTOS 7 ... Fails during configuration.
Re: NPRE on CENTOS 7 ... Fails during configuration.
What do you get if you run?
service xinetd restart
