Want to Monitor VMs using Nagios Core
AB777
Post by AB777 »
Hello guys,
I am new to nagios so I need help. I have completed the installation of Nagios core successfully and monitoring the othr linux server using NRPE. On this linux server we are hosting some VMs using Nimbus Infrastructure. I want to monitor these VMs for basic details like CPU load, Disk usage, services etc.
Is there any plugin or add-on to do so?
Second is that, To monitor the VMs do i supposed to install any plugin on the VM-image or it can be done without touching the VM-image.
Please Help..!!
Thanx in Advance..:)
agriffin
Re: Want to Monitor VMs using Nagios Core
Post by agriffin »
I found instructions for installing these plugins for nimbus in my search. Also, you can monitor each individual VM exactly as if they were physical machines. This means you would install NRPE on each VM like you've done with your other linux servers.
