Hi Team,
Im trying to build Dependency mapping at Host level to check for NCPA Agent Status so is it possible to Create hierarchical dependency to avoid running monitors based on scenario :
Scenario 1 : Server is not reachable
Host Down : PING fails
Agent Down : Agent API is NOT responding
Scenario 2 : Server is Up but Agent is NOT responding
Host Up: PING Success
All underlying monitors should not run in either of the scenarios - Disk , CPU , Memory , etc
How can we create a dependency so that if either Host Down or Agent Down then none of underlying monitors run ?
--Vamsi
Dependency Mapping - Host & Service to all monitors
veeravamsi
benjaminsmith
Re: Dependency Mapping - Host & Service to all monitors
Hello Vamsi,
You can use service dependencies in Nagios XI to set this up. So if you create a ping check as a service for the server, and then define service dependencies between this check and the other services, you can configure the execution and notification settings as desired.
Service dependencies can be configured in Nagios XI by going to Configure > CCM > Advanced > Service Dependencies (see screenshot). You'll find documentation explaining the settings below.
https://support.nagios.com/kb/article.php?id=505
https://assets.nagios.com/downloads/nag ... ncies.html
Let me know if that will work for your environment.
veeravamsi
Perfect . Im trying to Create NCPA Agent Monitor ( using check_http ) to test Agent Availability before running any of the underlying monitors. So this approach of Service Dependency works fine , However two questions :
1. We have to create this dependency for each server ? Meaning we have to manually select the Services ( CPU , Memory , Disk , etc ) and if these are varying ( means some servers have Service check ? ) then its lot of complexity or involves manual work ?
2. Also can we include this as part of Template Deployment ? Or is there a way to make this global just like we change host_dependency_check=1 or some variable to say dont run any of the monitors if Host is unreachable ?
Do let us know if there is better way of handling this situation : My goal is not run underlying services if Host or Agent is not working ?
--Vamsi
--Vamsi
benjaminsmith
Hi Vamsi,
It sounds like this approach will work for you. Below are the answers to your questions.
See:
Nagios XI - Service Dependencies
1. There isn't a template for service dependencies, so it would take some manual selection to set this up, but you might be able to save some time organizing the services into groups.We have to create this dependency for each server? Meaning we have to manually select the Services ( CPU , Memory , Disk , etc ) and if these are varying ( means some servers have Service check ? ) then its lot of complexity or involves manual work ?
2. There is a configuration setting the main Nagios.cfg file that will allow you to disable service checks when the host is down. This is a global setting, but very easy to implement.Also can we include this as part of Template Deployment? Or is there a way to make this global just like we change host_dependency_check=1 or some variable to say dont run any of the monitors if Host is unreachable?
See:
veeravamsi
Thanks Benjamin . I cannot access the document referred on the KB link .
So if i want to make 'NCPA Agent' as master Service across all Services , Do we need to have separate Entry for each Server ? or can we logically using Host/Service Groups and make them generic ?
On the second point - Do you have any other option on nagios.cfg ( similar to host_down_disable_service_checks=1 ) which i set for NCPA Agent Service like ncpa_service_down_disable_checks=1
We can't either, @benjaminsmith says he's going to try to track that article down.
How many total NCPA services do you think your XI system will have once you have them all in?
See here for examples of some time saving tips/tricks of how it can be setup:
https://assets.nagios.com/downloads/nag ... dependency
The "ncpa_service_down_disable_checks" functionality doesn't exist. You'll only be able to do it with service dependencies.
Thank you
Thank you
veeravamsi
Awesome
. Do you have any sample Rule based on your experience that helps us to create dependency Mapping for
NCPA Agent Status ( Primary or Main Service ) and rest all are dependent services.
As we will have 1000's of Servers having NCPA Agent and writing separate rule for each one is not ideal solution. So i was thinking to have Single Rule that helps us do this Job . Any suggestions ?
I'm struggling to find a way to do this without you defining them individually for each host.
My recommendation would probably be for you to change your host check from a Ping check to an NCPA agent check (just set it up like the master service), then set host_down_disable_service_checks=1 in your /usr/local/nagios/etc/nagios.cfg, and then restart the nagios service.
That way if the agent is down, the host will still nofify you, but the other NCPA services for the host won't run, which accomplishes what you're trying to do.
Those are really your only options after trying to get this done in a lab environment.
veeravamsi
Thank you for your suggestion . This is the current configuration we have ( NCPA Check @ Host Level ) but when NCPA is not communicating it triggers Host Down error which is what we are trying to avoid.
How often do you have it that the agent is down and the host is still pinging? Is this a common problem in your environment?
