Log file content monitoring on client server
surbsing
Post by surbsing »
Hey, I have to monitor the content of one file over client server(i.e, Windows Server) through Nagios Core. How could I do it.
Please help.
Re: Log file content monitoring on client server
Post by Box293 »
I honestly would not use Nagios Core as a method of log file monitoring.
You could look at using the free license of Nagios Log Server, it is a much better monitoring application for log files.
surbsing
Post by surbsing »
Yeah ... But is there a way to get the monitoring done by using Core... If you could help me in this it will be great
Post by Box293 »
This is the only way I know how:
https://docs.nsclient.org/reference/check/CheckLogFile/
However the method is something I just can't recommend. It would be worth your time to invest in running up a Nagios Log Server to do the monitoring, Nagios Core just isn't suited for log file monitoring.
