check_snmp plugin query - reverse warning and critical?
Guyver1
Post by Guyver1 »
Query:
Can you set the -w and -c of check_snmp to be say -w <300 ?
Reasoning:
We are monitoring our Wireless Access Controllers via check_snmp and we want to alert when the number of AP's connected to it drop BELOW certain thresholds, this means the warning and critical counters need to work in reverse. (where normal is 316 AP's, but then a warning and a critical need to be lower than the normal, not higher)
Is this possible using my example above or another method?
Re: check_snmp plugin query - reverse warning and critical?
Yes but different format, see
https://www.nagios-plugins.org/doc/guid ... HOLDFORMAT
for THRESHOLD format and examples.
Guyver1
Post by Guyver1 »
Excellent, thank you very much :D
Guyver1 wrote:Excellent, thank you very much :D
No problem
Locking thread
