Hi Team,
We have created Custom Scripts Plugins for Monitoring and its plotting Performance Reports Fine. Currently i have disabled Monitoring on them for two days because of Events/Alerts . Now im trying to find out where i can see historical Reports to see its health for last month ?
Thank you !
--Vamsi
Performance Graphs(Historical Reports) on Disabled Monitors
veeravamsi
Re: Performance Graphs(Historical Reports) on Disabled Monit
Hello Vamsi!
You can choose different time periods for the performance graphs, which will give you a historical view.
Also, you may be interested in the State History Report, which will show you a table of every time a particular service (or all services) changed state. Note that it only shows the ones that actually changed--if you had 100% availability of a service, it will show you nothing. If there was any state change during the time you query, you'll get a nice table that shows what happened and when. You can download this as a CSV if you need to do something else with it, also.
To get to this, go to Reports at the top, and you'll find State History on the left. There are a number of dropdowns to narrow your search, change the time period, etc.
The Service Alert Histogram will also show you a graphical view over time of any alerts that occurred during the time period you specify, for one particular service or all of them. Do note, however, that the data is smoothed over time, so if you look at an entire month, you may not see brief events, whereas if you look at a shorter time period (a week, a day...), you'll see the alerts on the graph.
Does this answer your question? Let me know if I can provide more detail.
--Jeffrey
--Jeffrey
veeravamsi
Awesome. This is exactly what im looking for.
One follow-up question on this is i don't see any of my Custom Service Monitors (using Plugins) - Like 'Temperature' which we created in the Service list on Reports -> Alert Histogram or any other section which i get to 'filter' on Service.
I can open new Thread if you want me to on this query. Appreciate all your help. Thanks !
--Vamsi
--Vamsi
Lets do that as it is an unrelated issueveeravamsi wrote:I can open new Thread if you want me to on this query. Appreciate all your help. Thanks !
Great!veeravamsi wrote:Awesome. This is exactly what im looking for.
Locking thread
