CGI Access Permission Issues
mdiorio
Post by mdiorio »
I'm using Kerberos Auth with Nagios to pass my Windows username/password though for authentication. This is working pretty well now.
I add a user to Nagios with their contact name as username@DOMAIN, and when they go to the Nagios site, it shows up, "Logged in as user@DOMAIN". Great! Now this user is added to the Admins contact group. In the cgi.cfg file, I added the admins group to all the CGI permissions, and I can access *most* all areas of the Nagios site.
However, I am having issues accessing Process Info (config.cgi) and Configuration (config.cgi). If I add my user@DOMAIN directly to the appropriate lines in cgi.conf, I can access these areas just fine.
So why is it that some areas allow using group membership for CGI access, while these two do not?
I don't want to have to manually go in and edit my CGI access permissions every time I add a new user to the system, it just doesn't seem smart.
Any ideas on what might be causing this or a workaround? Thank you.
Max
jsmurphy
Re: CGI Access Permission Issues
Post by jsmurphy »
That's because it's probably not working at all: http://nagios.sourceforge.net/docs/3_0/cgiauth.html
The relevant part of the text is the default permissions section for an authenticated contact user, you can't actually use a contact group as a valid reference in the cgi.conf.
So to answer your question as to how to manage these permissions, back when I was using Core I wrote a script that synchronizes an AD group with the cgi.conf. Otherwise you are a bit stuck with managing them manually I am afraid. You will also find that under your current methodology that if you were to create a host that didn't belong to the Nagiosadmins group that your admins would not be able to see it in the GUI (which... may or may not be desirable).
