blasthunter
Posts: 4 Joined: Tue Apr 16, 2019 10:43 am
Post
by blasthunter » Mon Apr 06, 2020 5:05 pm
Hi guys!
i need your help again...
when i execute check_mssql with nagios user and root user the check runs smoothly, but in the nagios web still appears to me "CRITICAL - could not load perl module DBD::Sybase"
but at the terminal level everything looks good, what could it be?
benjaminsmith
Posts: 5324 Joined: Wed Aug 22, 2018 4:39 pm
Post
by benjaminsmith » Thu Apr 09, 2020 2:44 pm
Hello
@blasthunter ,
Well, I suspect that the nagios user does not have access to DBD::Sybase. What happens you when you type:
and then run it again from the command line. Does it fail this time?
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
Be sure to check out our
Knowledgebase for helpful articles and solutions!
blasthunter
Post
by blasthunter » Thu Apr 09, 2020 4:13 pm
the problem was solved by installing java-devel
thanks for the help, greetings from chile
benjaminsmith
Post
by benjaminsmith » Fri Apr 10, 2020 2:49 pm
I would love to go to Chile someday!
I'll close up this thread and thank you for visiting the Nagios Community Support Forum.
Privacy Policy .
