This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
gixxx11
Post
by gixxx11 »
On occasion I get the following error when runing a mssql check:
ERROR: In range threshold START:END, START must be less than or equal to END
But 90% of the time I get the expect output of a 1 or 0. I'm not sure where to even begin on fixing this.
/usr/local/nagios/libexec/check_mssql -H 192.168.#.# -d dbname -U user -P 'password' -w 1 -c 1 -p 1433 -r "0" -q "exec dbo.usp_AutoEmailMonitor"
jdunitz
Post
by jdunitz »
This appears to have been a bug in an older version of check_mssql.
Someone else had a similar problem a few years ago:
https://support.nagios.com/forum/viewto ... =6&t=36336
Check the version you're running, in case you somehow ended up with an old one.
If yours is current, and you're still having this problem, let us know and we'll go from there.
Thanks!
--Jeffrey
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
