Using check_ncpa to check MS Exchange Queue
We have a request to monitor our Exchange 2016 Queue. I've tried calling a couple different PowerShell scripts, including NagiosMonitoring_Exchange2016QueueHealth_V2.2.ps1, but I'm getting the same error attempting to load the SNAP-IN (see below). I've seen a number of posts about setting up the Exchange Queue checks, but it looks like that's been with NSClient. We are using NCPA. I believe this is a credentials/access issue. Thanks in advance for your help.
-M "plugins/NagiosMonitoring_Exchange2016QueueHealth_V2.2.ps1"
Add-PSSnapin : No snap-ins have been registered for Windows PowerShell version
5.
At C:\Program Files
(x86)\Nagios\NCPA\plugins\NagiosMonitoring_Exchange2016QueueHealth_V2.2.ps1:62
char:4
+ Add-PSSnapin Microsoft.Exchange.Management.PowerShell.SnapIn
+ CategoryInfo : InvalidArgument: (Microsoft.Excha...werShell.Sna
pIn:String) [Add-PSSnapin], PSArgumentException
+ FullyQualifiedErrorId : AddPSSnapInRead,Microsoft.PowerShell.Commands.Ad
dPSSnapinCommand
Get-Queue : The term 'Get-Queue' is not recognized as the name of a cmdlet,
function, script file, or operable program. Check the spelling of the name, or
if a path was included, verify that the path is correct and try again.
At C:\Program Files
(x86)\Nagios\NCPA\plugins\NagiosMonitoring_Exchange2016QueueHealth_V2.2.ps1:74
char:20
+ ForEach ($Queue in Get-Queue -Server $env:computername)
+ CategoryInfo : ObjectNotFound: (Get-Queue:String) [], CommandNo
tFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
OK: All mail queues within limits. |queue=;10;20;0
5.
At C:\Program Files
char:4
dPSSnapinCommand
At C:\Program Files
char:20
tFoundException
Re: Using check_ncpa to check MS Exchange Queue
Please make sure that you run the PowerShell on the Exchange Server host.
Please run this command on the system you're running it on and send us the full output:
Please attach your ncpa.cfg file from the remote NCPA host as well. This may be a 32 vs 64 bit powershell issue.
get-pssnapin –registeredRe: Using check_ncpa to check MS Exchange Queue
PSVersion : 2.0
Description : Register cmdlets for Content Engine
PSVersion : 2.0
Description : Register cmdlets for Host Controller
PSVersion : 2.0
Description : Register cmdlets for InteractionEngine
PSVersion : 2.0
Description : Register cmdlets for Juno
PSVersion : 1.0
Description : Admin Tasks for the Exchange Server
PSVersion : 1.0
Description : Setup Tasks for the Exchange Server
PSVersion : 1.0
PSVersion : 1.0
Description : Support Tasks for the Exchange Server
PSVersion : 2.0
Description : Microsoft Forefront Filtering PowerShell Interface
PSVersion : 2.0
Description : Register cmdlets for SearchCore
I've attached the ncpa.cfg. It is set to 32-bit (default), but I did try switching to 64-bit as described in the file,
Since windows NCPA is 32-bit, if you need to use 64-bit powershell, try the following for
# the powershell plugin definition:
# .ps1 = c:\windows\sysnative\windowspowershell\v1.0\powershell.exe -ExecutionPolicy Unrestricted -File $plugin_name $plugin_args
Of note, we have a policy set to allow PowerShell in RemoteSigned.
PSVersion : 2.0
PSVersion : 2.0
PSVersion : 2.0
PSVersion : 2.0
PSVersion : 1.0
PSVersion : 1.0
PSVersion : 1.0
PSVersion : 1.0
PSVersion : 2.0
PSVersion : 2.0
Is your ncpa_listener service running as Local System or something else? If Local System it should have permissions to do it.
I can't really think of any other reason that it would be failing, it has to be the 32/64 thing. I found through some searching it requires 64 bit powershell.
Please try doing it again, edit your ncpa.cfg and change this:
To this:
Then restart the ncpa_listener service and test.
Let us know the results.
.ps1 = powershell -ExecutionPolicy Bypass -File $plugin_name $plugin_argsCode: Select all
.ps1 = c:\windows\sysnative\windowspowershell\v1.0\powershell.exe -ExecutionPolicy Unrestricted -File $plugin_name $plugin_argsLet us know the results.
I assume that the changes to the ncpa.cfg needed to be made on the the Windows client, not the Nagios server.
I updated the ncpa.cfg as suggested, but I get the same error.
So I then created a custom PS script to give me the bit version of PowerShell using the following command:
[System.Environment]::Is64BitProcess
If I run it on the local system, I get back true, however, if I run the script from the Nagios command line, I get false.
I then tried changing the path in the ncpa.cfg to system32, instead of sysnative, still false.
I then tried changing powershell.exe into something random and it still ran powershell and returned false.
So its as if the path is in the ncpa.cfg isn't being recognized.
We are running NCPA version 2.1.8.
I just labbed it up with both 2.1.8 and 2.2.0 and they are both working.
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/Re: Using check_ncpa to check MS Exchange Queue
If you run that exectuable onthe command line:
and then
does it return true?
What if you try running:
c:\windows\sysnative\windowspowershell\v1.0\powershell.exeCode: Select all
[Environment]::Is64BitProcess What if you try running:
%SystemRoot%\system32\WindowsPowerShell\v1.0\powershell.exe
[Environment]::Is64BitProcessAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
So I believe I have resolved the powershell problem with ncpa.cfg. It looks as though puppet was not disabled, as expected. I was able to correct the issue and run some further testing on my test system:
puppet agent --disable "testing"
Stop the NCPA Listener
Update the ncpa.cfg
Start the NCPA Listener
Result: False
Result: True
I'm still working with our Exchange admin to verify that this resolves the issue on his system and that the script will report results.
Update the ncpa.cfg
Result: False
Result: True
Sounds good, let us know the results.
